      Chico, California Nor-Cal
      SLP T-ram Fuel injection Firehawk
      I have on of these ultra rare set ups. I may swap it in place of my Holley stealthram, I'm looking for flow numbers for the T-ram. It sure look wicked cool! Anyone? It may go up for sale
      [email protected]
      FL.
      I cant give you any actuall flow #'s but they are decent. They flow the same as a SuperRam/HSR combo..
      Prob shine in diff RPM areas because of the design diff.
      You can find some info over on the camaro forums
      http://thirdgen.org/techbb2/showthre...highlight=TRam
      It Deff looks better then a HSR. Ihave had almost one of every TPI setup. HSR/SR/LTR setup/MR/Lt1 everything but a T Ram..lol.
      For looks Id say go with the T Ram. It should perform just as well as the HSR and look better!
      92 Vert | 383 LT1 | Ported heads | Callies dragon slayer crank & rods | JE Pistons | Novi 2000 supercharger | SLP Headers | spohon suspension |TH400 | 9bolt with 3.45's.
      Yardley, PA.
      Hey man, we were just exchanging emails this week. I will get you the results of those tests...like I said, the HSR did alot better than every other intake. I am in those thirdgen.org posts over there as Raptor Pilot in 99% of the T-RAM stuff.
      Questions- Are you using an auto or manual trans? If auto, you are going to need the cruise/auto cable bracket. Do you have the custom fuel lines? Water neck?
      '70 Formula 400 PT Project
      '88 GTA Notchback
      t-ram
      The cable bracket appears to be modified. I will be using a manual trans. I would like to use this, but it's value may sway me to let it go. I do have quite a lot invested. It just looks soooo cool. Hey by the way will it clear tall valve covers? It looks aweful close???
      thanks
      Yardley, PA.
      It'll be tight. Never seen one with tall's. I doubt it will.
      '88 GTA Notchback
      I am looking to sell it first $2000 obo
      Jan 2012
      Might be interested. I emailed you and never got a response. Do you still have this? Can you send me some pic's and give me a rundown of what all you have with it? [email protected].
