    Results 1 to 9 of 9
      Nov 2007
      mcleod bellhousing
      I am installing a TKO into my 72 chevelle. I have a mcleod scatter shield and the clutch fork seems a bit short. Does anyone know if the clutch fork from the muncie is the same as for a mcleod? Thanks
      TuoCo, CA
      it was on my camaro.
      Steve
      Check it Out Here
      Dec 2002
      Lost Wages, Nevada
      It depends on the pivot height.
      Nov 2007
      just seems a bit too short and I can't seem to get it lined up. Any ideas?
      Manteca, CA
      It was the same fork for my '69 Camaro...went from Muncie 4 speed to TKO 600...same fork, no problems....
      Can you post pix ??
      Nov 2007
      I gave up last night. I am going to call mcleod. I think the problem is the ball stud is the wrong length. Hopefully an adjustable will solve the problem.
      Sep 2001
      Accord, NY
      I used the long GM stud on my 69 and it worked perfectly.
      68 camaro - SOLD
      Manteca, CA
      The adjustable ball stud is ridiculously priced...like $60.... when I did my change over Jeff at CC5S suggested the the adjustable TO bearing instead....
      Quote Originally Posted by DRJDVM's '69
      Ditto for me on the adjustble TO bearing--go with that instead, you should have no problems. Jeff also has two different forks, call him, he is a sponsor, and always very helpful!
