Thread: mini tub shock question
02-05-2005 #1
New to Pro-Touring
- Nov 2004
- 20
I have a 68 camaro that I am building flat mini tubs for, my first question is since I am not tubbing as far as the dse tubs go, I am only going to the frame rails will the dse shock crossmember be long enough, does any one have the length? Also where should my upper shock mount be, I am planning on using the stock multileaf lower mount. Will I have to get shorter shocks since Im going inboard? I will be running dse 3 inch drop leafs. What shocks do you guys recomend ?
I am open to any suggestions involving mounting, packaging and locations of shock mounts?
THANKS A LOT
