    Page 2 of 2 FirstFirst 1 2
    Results 21 to 40 of 43
      Cartersville, GA
      Wow, I have gotten way behind on this thread! Life has gotten in the way, but I am finally making some more progress on the car. I'll post some updates and pics later.
      Joe Hinds
      Iceland
      Country Flag: Iceland
      iceland
      Dunwoody, GA
      Great to know you're still out there Joe. Hey, I found a new shop that has an in ground dynojet. The company is red star performance. They are in Oxford which is just north of Convington. www.redstarperformance.com
      Very small shop but they seem to be getting a good reputation.
      Trey
      ~ Jon Hammond
      Cartersville, GA
      Wow, eleven months since the last post! A lot has changed since my last post; the Camaro SS that was going to be the donor was sold (with the 383), I did get engaged, and I am now self-employed, building cars (I used to be a stockbroker!) and doing performance and general repair work. I'll be opening a shop sometime after the first of the year (still looking for a suitable location).
      I have made a few changes in my plan for the build, however. I'm going with an iron block 6.0 stroker, with L76 heads and an Edelbrock Victor single plane. I'll use a 4 barrel-style throttle body. The T56 willl remain, but I do have some different plans for the rearend. I had originally planned to do the early C3 iron diff on the original batwing, but since my new power plans may be a little much for that, and a Tom's 12 bolt is a little too much, I'm adapting another IRS centersection to the car. I have two different ideas on that, one being fairly cheap and simple (8.8 Ford IRS), the other...well. a little more complex and expensive, but definitely bulletproof. More on that when I get to that stage,
      I'll post more pics as soon as I can get them uploaded, but for a quick update I have done the following since the last post: removed both doors, removed the interior, removed the engine/trans, welded in new floorpans, stripped the rest of the paint from the main body, and removed the front clip.
      Joe Hinds
      Cartersville, GA
      Ok, I'll start with the underhood area. The engine and trans were pulled as a unit, and sold($650). It still ran well, for a basically stock engine, but was far from what I want for this car. As you can see, its pretty grungy under the hood, but its in decent shape otherwise. The front clip will be coming off soon; its not damaged too badly (repairable), but there is some surface rust in the corners under the windshield frame area of the birdcage, and the only way to fix it right is to get the clip out of the way.
      Joe Hinds
      Cartersville, GA
      I got a bit ahead of myself while cutting out and replacing the passenger side floorpan, and didn't get any before or progress pics, but I will take plenty when I do the other side. Here is the driver's side, after rust treatment. I wasn't happy with it, so its being cut out next.
      Joe Hinds
      Cartersville, GA
      When doing any kind of sheetmetal work, one of the hardest parts is holding the panel in the correct position while you begin tacking it in place. The solution to this dilemma is a simple spring loaded, removable, rivet-like device called a Cleco. Originally developed for aircraft construction, they work great for any sheetmetal project. Just drill a hole through the overlapping panels (either 1/8 or 3/16, they are sold in both sizes), insert the Cleco into the Cleco pliers, and squeeze to extend the spring loaded tip. Insert the Cleco into the hole, and release the pliers, and the tip expands to hold the panels in place. Summit sells a kit, SUM-G1850, that includes the pliers and 10 1/8 and 15 3/16 pins, for $17.95. Extra pins in 1/8 are SUM-G1852; 3/16 are SUM-G1853. Each is $12.95 for a pack of 20.
      Joe Hinds
      Dunwoody, GA
      Looks good Joe. You're doing fine work to that 81. Most people would toss it aside which is a shame. I think they can look great. Keep it up and good luck with the business.
      Trey
      ~ Jon Hammond
      Cartersville, GA
      Quote Originally Posted by WS6 View Post
      Thanks Trey! There are some really nice rubber bumper cars out there, but I have seen few that have gone as far as this one is going. The 81s will probably never be worthwhile to restore to original (you can get a nice one for twice what we paid for this one), but to me they are perfect for a Pro Touring build. I think they are some of the best looking Vettes ever made. They just need a lot of help in the suspension, power, and braking department!
      Joe Hinds
      Oct 2006
      Morristown, NJ
      Good work so far. I have always had a soft spot for the 81 Vettes. My dad had one growing up. I took my driving test in it.
      1973 Camaro Type LT/RS
      http://www.apiem.com/camaro
      Cartersville, GA
      Quote Originally Posted by amargari View Post
      Thanks! Honestly, I never thought I would build a Vette...growing up they were pretty much out of reach (back in the days when you could buy a nice small block Nova with a 12 bolt for $1500). We just sort of stumbled across this one, and bought it. I have always loved the body style, though.
      Joe Hinds
      dayton, oh
      nice work, nice job documenting it. I have pretty much all the same tools, doing the same job to my 442. fun, isn't it?
      dave.t
      74 Javelin AMX - stocker
      Cartersville, GA
      Quote Originally Posted by jackfrost View Post
      As hard as it is to beleive sometimes, I really love doing this stuff! With every car I have ever put together, I can honestly say that I get more enjoyment out of the building process than anything else. Once they are done, I usually lose interest and want to build something else. This one is a keeper, though...it was a gift from my fiancee, and she is behind the buildup 100%. She just wishes it was going faster
      Joe Hinds
