04-19-2008 #1
- Oct 2007
- 10
What return style Fuel Pressure Regulator for Carb with EFI In-Tank Pump?
I am going to install a sump and run Dual EFI In-Tank Pumps (pumps from a Late Model Mustang Cobra)
I plan to run 1/2" supply and return lines.
Motor should make over 500, but less than 600 HP.
Please recommend regulator/s that would work well for this setup. Please indicate what features the regulators have that causes you to recommend them.
I will be using a Quadrajet initially but may eventually go to EFI so it would be nice to have a requlator that I could "upgrade" to work well with EFI if I ever make the conversion.
Thanks, Joel
04-22-2008 #2check out RobbMc. he has a regulator that can convert between hi-pressure EFI, and lo-pressure carb with the swap of a spring. also can be configured for by-pass or dead-head. i have bought a few products from him, they are great, and he never stops answering questions and helping out.
http://www.robbmcperformance.com/
