    Thread: will it work?
      livermore ca
      will it work?
      ok i am tired of messing with my 700r4. i have a m22 already and i am just going to put that in the car and later on get a gearvendor. will the tranny hook up to a 95 lt1 block? i dont think there is a difference but just wanted to see.... also anything i should look out for while converting the chevelle from a auto to a 4 speed?
      https://www.pro-touring.com/forum/sh...ad.php?t=22724
      65ss chevelle
      95 lt1 LE2 heads gm847 cam, 1.6 gold sereis roller rockers,52mm tb,37lb racetronix injectors. hooker headers
      63ss nova
      350:cam headers,roller rockers.pete jackson gear drive,
      th350 shift kit 3,500 stall
      3:73
      **Drive it like you stole it!!
      CHICAGO SUBURBS
      Everything should bolt up, except you'd need a flywheel for the engine year. The clutch and everything else from the '65 would work. The exaust/headers you've used could cause trouble with the clutch Z-bar, the rest should be easy.
      livermore ca
      what about the bellhousing?
      65ss chevelle
      63ss nova
      3:73
      Dallas TX
      Bell housing bolt pattern is the same a SBC/BBC.
      TuoCo, CA
      if you want the gear vendor, talk to Mark LW over at Team Camaro....
      http://www.camaros.net/forums/showthread.php?t=132046
      Steve
      Check it Out Here
