Results 1 to 9 of 9
Thread: boxing front lower control arms
04-16-2008 #1
- Oct 2007
- ridgefield ct
- 876
what kind/thickness metal do i need for this? is just flat pieces across the bottom fine, or is there a specific way it should be done?
just in case it makes a diff. it's for an 87 monte. and i'm also putting in the del-a-lum bushings.
thanks
04-17-2008 #2
- Jul 2006
- Chesapeake, VA
- 678
It's a lot easier to weld if you use the same thickness as the control arm. I'm not sure just what those control arms look like but most have a spring pocket that goes close to where your boxing plate will cross. If you can tie those together it will be stronger.
04-17-2008 #3
