Thread: Project "Shadow" LS2 Begins
04-15-2008 #1
Project "Black Magic" LS2 Begins
Just received my new LS2 Motor! along with the upgrades i will be doing is putting behind the LS2 motor will be a Tremec TKO 600 5 speed! and the new Strange 12bolt rear end with a 3.73 gears.
Here is the specs on the Motor and new heads!
LS-2 Motor:
Bore and stroke: 4.00 x 3.62 in.
Displacement: 364 cu. in. (5.967 liters)
Compression: 10.9:1
Induction System: Sequential fuel injection
Gross Horsepower (SAE net) 400 @ 6000 rpm
Gross Torque (SAE net) 400 lb.-ft. @ 4400 rpm
Block All-new 319-T5 Aluminum
SLP #100225 Harmonic Balancer/Crank Underdrive Pulley, Steel, Silver Zinc Chromate
Heads: Livernois Motorsports
Stage 2 CNC Ported Stage 2 GM LS-Series Cylinder Heads
New GM 243 casting
5 axis CNC machined
Fully assembled
220cc Intake Runner
Intake Flow Rate 305 CFM
Exhaust Flow Rate 235 CFM
New 2.000 intake valves / 1.550 exhaust valves
GM valve seals and locks
Livernois dual coil valve springs good to ~ .690 lift
Manley titanium retainers.
Fast 92mm Intake
Fast 92mm T.B.
AutoKraft LS2 Oil pan package
Will keep you posted on the build and progress of this conversion!
Bill
Bill Panouses
Evade Camaro http://www.facebook.com/pages/Evade-...71454739554636
www.evadecamaro.com
