      Red Deer, Alberta, Canada
      Tightening spindle nut
      I can't remember what the procedure is for tightening the spindle nut on a front spindle to properly squish the bearings. If that makes sense lol. It was something like, tighten finger tight, then 2 turns and back 1/2 turn or something.
      Any help would be great
      -matt
      Matt
      Instagram: Cst_koon
      May 2002
      Northern California
      Snug down, spin hub/rotor, then back off 1/8 turn or just so you can just about move the washer back and forth with a screw driver.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Mar 2004
      Mid-Michigan
      If this is the stock spindle most procedures will tell you to torque it down to 12 lb/ft while spinning the rotor then back the nut off to the first hole in the castle nut for the cotter pin.
      Mark
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      Central Illinois
      Torque to about 15 lb/ft to seat, then back it off. Now install finger tight. If you can't get the cotter pin to slide through - then back the nut off until you can. Don't go tighter.
      '68 442 convertible
      5 SPEED - EFI
      '66 442 Hardtop
      in process
      alrighty, thanks guys!!!
      its a the coleman spindle with impala hub.
      Matt
      Instagram: Cst_koon
      Quote Originally Posted by protour_chevelle
      Matt,
      Be careful when using some of those circle track parts. They were never designed for heavy cars or the things that a street car might encounter, like big pot holes.
      Its the same setup that Dennis ran. I've already run the setup for a year but couldn't remember the castle nut torque spec. Its holding up just fine
      The drop tech spindles are more sketchy than these and they are a cast piece!
      Matt
      Instagram: Cst_koon
