      dayton, oh
      how to clean underbody?
      i'm starting to get into the underside of the body on my car, and was wondering if ya'll have some tips. I don't need it super-clean, just clean enough to spray on some epoxy. it looks like a mish-mash of oem paint and undercoating poorly sprayed on. oh, and rust.
      tools? chemicals?
      dave.t
      74 Javelin AMX - stocker
      north central Iowa
      as far as the undercoating the best way that i have found to get that off is with a torch in one hand and a scraper/putty knife in the other, heat a small spot then scrape, repeat.
      Theres a product called peel away 7. You spread the stuff on like mayo and then you put a type of wax paper on top and then let it sit. Peel off the paper and scrape the under coating off.
      I found this stuff after scraping my under coat off-Figures.
      dayton, oh
      where do you get it?
      dave.t
