    Results 1 to 14 of 14
      Feb 2007
      USA, TN
      Idler Arm question
      Did they may more than one idler arm for the third gen Novas? I ask because mine is hitting the right header where it pivits. Is it possible it is a replacement that is bent slightly different? If so, what is the most accurate replacement part?
      I installed my new Dougs headers #368 and they fit great except it is resting against the idler arm where it pivots on the frame mount. I'm hoping it is an idler arm issue because I can easily get to all my plugs with angle plug heads and I can get to the starter wiring from the top.
      Central CA USA
      There are some variations.
      Can you post a pic of your current idler?
      Feb 2007
      USA, TN
      Here is the pic. By the way your 1st gen suspsension sight is awesome. It was my first stop for this problem.
      Dec 2007
      New York
      The difference in the arms is limited to the arm length (5.25" - almost 6") and would not make any difference in where the contact is in your case. I would check the header application. Check the engine frame mounts and see if they are from a big block? I believe they shift the engine to one side but not sure which one.
      Feb 2007
      USA, TN
      Will it hurt to bend the arm a little? I only need 1/16 to 1/8 inch.
      Central CA USA
      I doubt it's easy to bend. You might be able to insert a washer between the idler and frame on the upper bolt. Too much angle change would probably cause binding of the linkage.
      That idler is a stock type, probably the thinnest you will find. Many of them have plastic bushings inside and the header heat will hurt them.
      I was wondering if you could unbolt it from the frame and rotate the shaft 180 degrees, that would move it away a lot. Then add some spacers to move it back towards the headers. The spacers would need to be 1" diameter and probably 3/8" to 1/2" thick.
      David
      Feb 2007
      USA, TN
      Quote Originally Posted by David Pozzi
      I was wondering if you could unbolt it from the frame and rotate the shaft 180 degrees, that would move it away a lot. Then add some spacers to move it back towards the headers. The spacers would need to be 1" diameter and probably a half inch thick.
      David
      That is an idea worth trying. I would probably put a 1" wide, 1/2" thick plate in for a spacer, then shim from there. I just want to make sure my geometery doesn't get too messed up.
      Feb 2007
      USA, TN
      Quote Originally Posted by Ranaexcavating
      Took a closer look at the idler arm. If it were 3/4 inch down, it would probably clear the header. The header is bending towards the engine at that point. What do I need to measure to see how long mine is? Mine is 7.5 inches from the very top to the very bottom. Heck, maybe I have the wrong idler arm!
      Dec 2007
      New York
      Quote Originally Posted by TnBlkC230WZ
      No, the arm is the part that connects to the center link not the frame mount.
      Feb 2007
      USA, TN
      Mine is all one piece. The part that connects to the frame is what is giving me grief. I found the one from the frame I bought and it is two piece with a 5.25 inch frame mount. It has a different shape, but it hits as well. If I redrill the bottom frame mounting hole, moving it forward about 1/2 inch, everything fits. Just not sure what this will do to my handling and driving.
      May 2002
      Northern California
      Could you ding the header pipe a bit? 1/8" isn't much.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Feb 2007
      USA, TN
      That is definitely and option. I was trying to avoid that one
      Dec 2007
      New York
      I wouldn't drill any new holes to move it. Get a thick washer or make a spacer to add in between the upper mount that shouldn't have any adverse effect on your steering geometry.
      Good Luck
      Feb 2007
      USA, TN
      Good Luck
      I will try that first. I was also thinking of welding an extension onto the idler bracket and drilling the hole in that. that would easily let me go back to the original mount points. I would only need a 1/4 inch of movement to make that work.
