      Birmingham, Michigan
      pro-touring a 79 firebird
      trying to decide on a suspension package for my project. tell me what you think about these two packages. the car currently has a 403 olds, but i would like to swap in a big block in the near future. My goal is to get the suspension sorted out first!
      this is the Hotchkis system
      http://www.hotchkis.net/p-510-70-81-...all-block.aspx
      This is the Pro-Touring Fbody system. I would choose the Gt system
      http://www.pro-touringf-body.com/Suspension_kits.html
      1979 firebird!
      IL/TN
      keep in mind that the 403 is lighter than a BBC or Pontiac engine so you will run into issues with the front springs height, our kit used different springs for those engines, here is a pic of a Camaro w/sb GT kit
      https://www.protouringf-body.com "doing what they say can't be done"
      Do you recomend I go with the small block gt kit? I wont be swapping in a big block until next year, probably over the coming winter. When the big block is installed, can I simply switch the springs? Excuse the simple questions, this is my first project.
      Thank you
      Zack
      1979 firebird!
      IL/TN
      do you have A/C? if so just get the BB kit it will just sit a bit higher untill you put in the BB
      I dont have A/C or heat!
      1979 firebird!
      IL/TN
      well with the SB springs you can expect it to sit like this with the 403 no a/c
