      CT
      What dia. exaust pipe for LS1?
      Just wondering if you guys are using 2.5 or 3in and if there are problems with either..
      It is a 69 Camaro LS1 with heads and Cam.. I am using S&P headers and want to use Flowmaster mufflers with NO cats..
      Felton, DE
      I'm running Jegs universal x pipe kit in 3" with Hooker LTs. an x pipe will give you a nive probabaly 5-10rwhp 10-15rwtq gain.
      1994 Z28 - 13.52@110mph 2.1 60ft T56, bolt-ons, suspension
      1978 Datsun 2+2 - 6.0L LS1 swap in progress
      1968 Firebird, 2820 dry- 2000 LS1, D&D Viper T56, RAM clutch/flywheel, 236/236 .651/.651 110+4LSA cam, victor JR EFI, 4150 TB, 42lbers, painless harness, Moroso 7qt pan, sfc, trac bars, 3" x pipe side exits, Telstars-30"MT streets/skinnies, mini-tub, 8.5" posi, richmond 4.56s, Hooker lLTs, Denny N20 DS, Fast dual wideband, Shotgun street scoop.
      http://www.myspace.com/shawnmacananny
      CT
      Shawn,
      Is your system 3" all the way back or does it go to 2.5 at the tailpipes??
      Newbury Park, CA
      If it's a mild build then 2-1/2" should work fine but you will need a smooth 3" - 2-1/2" cone transition. Flowmaster makes these as well.
      I will also be running S&P headers, 3"-in/out X, Flowmaster cone reducers into Magnaflow 2-1/2" mufflers, 2-1/2" tailpipes. I had a similar setup on the previous engine and it seemed to work well.
      Felton, DE
      I'll be running side exits right before my rearwheels so i wont have tailpipes haha. You should be fine with reducing them to 2 1/2" pipe over the axels. I have a set of slip on header reducer cones with O2 bungs i got my my headers if ya need them. I'm running carbed and 3" so i ont need them.
      Santa Barbara, Ca
      My LS motor is putting out over 600 hp through a 2.5" exhaust with an x-pipe an 1 3/4" Stainless Works long tube headers. A 3" system would probably be better for me, but I have limited room under the car for that.
      For a H/C LS1, 2.5" should be more than fine.
      Andy
      Feb 2003
      Houston, TX
      From my experience with these engines, you should only need a dual 2.5" exhaust system if you are pushing less than 500 at the rear wheels. Then a 3" dual system would be better.
      Keep in mind that 4th gen f-bodies only run a dual 2.5 Y-pipe into a single 3" catback most of the time, and they easily put down 425-450 rwhp through a single 3" pipe.
      Co-Founder, LS1TECH.com
      www.DV8Motoring.com
