      Wichita, KS
      Evacuation - Collector or Pipe?
      Where are you guys welding in the check valve for the evacuation kit? I heard some people weld them into the collector and some weld them into the pipe because they don't want to mess up the collector.
      Thoughts?? Suggestions??
      In my opinion you could do it in either place... Doesn't really matter right...
      I'm doing a high end 1966 Chevelle build in the shop at the moment and I'm doing a vacuum pump evac system and I am going to plumb the rear of the passenger side valve cover for a -12 bulkhead fitting and I'll be using a Moroso pump, MARCH pulley and Stef's oil/air seperator and custom mounting brackets for use with a GM style serpentine belt drive on a SBC 400. It's a one-off design of mine but it'll be real slick once it's done. The problem I have with collector evac kits is the amount of blow-by in the exhaust-it can get problematic at the track if the officials think you're leaking oil somewhere. With a vacuum pump, you create negative crankcase pressure (I'm shooting for 10-14 inches using a regulator) which in this particular motor will free up quite a bit of power as well as ventilate the motor in a sanitary way. I'll post up some pics once it's completed. We'll be taking the car to the track around the 1st week in June. 696 dynoed hp with a 400 shot on top and a transbrake...oh yeah, baby.....
      [email protected]
      Wichita, KS
      Quote Originally Posted by gmachinz
      Sounds nice. Take some pics for sure when you have it bolted together.
      Your reasoning is exaxctly why I was thinking about welding the evac into the pipe and not the collector. If I ever want to go to a system like yours I won't have a collector with a hole in it.
