Thread: Power Valve Size
04-10-2008 #1
- May 2007
- Midwest City, Ok
- 306
Power Valve Size
I bought a motor about a month ago and the guy suggested getting the carb rebuilt. So I got the carb back about a week ago and the shop rebuilt it back to stock specs. I was wondering if with my motor specs I could get an idea of the correct or close to correct power valve size? The motor is not in the car right now and on an engine stand, but I would like to get the carb close to ready as possible.
502 Gen VI 4 bolt main, 9:1 CR
Melling hv oil pump
Crane solid roller p/n 168601 cam .615 .636 246 254 dur @ .050,
crane solid roller lifters
GMPP 12363400 Aluminum Rectangle port heads
GMPP 12361323 1.7 alum Rockers
Edelbrock victor jr 454-R intake
Crank Ext. ballanced, nitriated, crossed drilled gm p/n 10198922
Rods Forged 4340 Steel
Pistons GM P/N 12533507 Forged Aluminum
MSD Pro-Billet Dist.
04-11-2008 #2Per holley's website, if I remember right, you need to check the motor vacuum first. At op temp, if auto, in gear, and check the idle vacuum, then use a PV that is half of that reading.
Like 10" of vacuum, use a 5 power valve. Seems to have worked pretty well for me.94 S-10 / V8 / 6 speed / 8.5 rear / ATS spindles / QA1 coilovers / 14"C6Z brakes
