      Holley Electric Pumps...
      For those of you who have used them in your cars, have you ever had one go out?
      Here's why I ask: When I got my '67 Le Mans, it already had the Holly pump on there. It sounds like it's really weak, as opposed to other electric pumps that I've heard. I don't know exactly which pump it is but it's supplying a Holley 750 on top of a 455.
      I think I'm going to replace it but a friend of mine was saying that those things rarely go out.
      What do you all think? Ever had one go bad?
      Chicago - western burbs
      I've had a Holley Blue on my GTO for about 5 years now with no issues. 850 carb on a 455. Mounted right behind the rear bumper with a pre filter.
      the holley blue pumps usually hold up for a long time. Like Rubes said, make sure you have a filter between the tank and the pump. Check the filter, make sure its not clogged. fuel pump placement also has a lot to do with its lifespan. The fuel pump should be mounted in the rear of the car, acting as a pusher, it is MUCH less effective (and wrong) to mount it in the engine compartment and use it to pull fuel from the rear
      Quote Originally Posted by all wired
      I just took another look at it. It's a Holley Red, which puts out 97 GPH (according to the website). Maybe that's not enought for a 750 CFM carb on a 455 but I would think that it would be fine. I moved the filter from behind the pump to the front because I thought the filter might be hurting the ability of the pump to pull from the tank. That didn't help at all...
      I also noticed that the previous owner had stuck a 25 Amp blade fuse in the fuse carrier supplying the power to the pump. The Holley website says it only needs a 7.5 Amp fuse.
      After that little discovery, I'm thinking it seriously might be cooked. Not by any defect of the pump though, simply because of the idiot who put in a fuse that's 3 times the load that it should have been.
      Henderson,NV
      The reason he put that big fuse in there is because the pump was shot and pulling to many amps more than likely. It was probably popping that little fuse. You can measure the amperage with a multimeter. If it is greater than the recommended fuse, you know it's junk.
      Todd
      Quote Originally Posted by Vegas69
      I never considered that.
      I think I'm going to try a new pump. Thanks for helping me put 2 + 2 together...
