    Results 1 to 9 of 9
      Oct 2007
      ridgefield ct
      g-body bump stops
      i'm lowering and upgrading my 87 monte. what bump stops should i use, front and rear?
      one fell off, i think it came off the axle by the yoke. does it mount on the axle or on the body above it? how important is it?
      Eastern Virginia
      don't know about the back, but for the front I have the ZQ8 S10 ones. There is a lot of write ups on them & praise to how good they are. Search on Montecarloss.com for info, I believe that is where I found out about them.
      Scot
      86 Monte SS
      Oct 2007
      ridgefield ct
      i've found 2 different numbers 15989674 and 15956547 which do i use?
      Eastern Virginia
      I think they changed part numbers since I bought mine. And I don't think I have the boxes mine came in, so I may not be able to tell you for sure what the number is. I'll see what I can find.
      Scot
      86 Monte SS
      Ontario, Calif.
      The ones I bought a year or so ago are #15956547. I have them front and back on my Elky.
      '82 El Camino w/ 95 LT1
      '02 Camaro SS a few mods
      '04 Silverado - the beater
      Oct 2007
      ridgefield ct
      the zq8's are just for the lower control arms right? what about the upper? and does anyone have any opinions on the rears? even just stock vs. poly.
      Farmington Hills, MI
      Bump Stops? What are those?
      JEFF SHORTT
      -IDEAL STEEL
      Eastern Virginia
      Quote Originally Posted by megaladon6
      Uppers? Don't recall seeing those on the factory G body uppers.
      Scot
      86 Monte SS
      Oct 2007
      ridgefield ct
      they're small but they are there. course i don't know how important they are. i'm not too worried about them, mostly the rear.
