04-06-2008 #1
What Flywheel?? // MARKVI Internal Balanced
Can someone tell me what Flywheel they are using with the Mark VI Block?
Here is my setup...
Mark VI Block w/ Forged Crank / Internally Balanced / 600HP
Muncie M21 4-Speed
Centerforce Clutch w/ 10.4 Disc
I am having a hard time finding a Flywheel that is listed as Internally Balanced. Most all flywheels I can find say Externally Balanced. I have found a McLeod Flywheel but I can't get it shipped until 4/18/08.
Here are part numbers / manufacturers I have located...
McLeod 460130-4C - This might work, but doesn't ship for a while.
RAM 1530 - Shows Externally Balanced
Centerforce - Shows for Cast Crank
Anyone with a setup like mine please let me know what you went with.
Thanks!
04-06-2008 #2
Starting The Transformation
- Sep 2004
- 135
I'd use a stock nodular iron flywheel IF one is made by GM and then have it's offset balance dog-knot machined off and then neutrally balanced since you internally balanced an otherwise externally balanced rotating assembly and go.
pdq67
04-06-2008 #3
