      Tire size and wheel width help?
      I have a 1970 nova thats going to be running AME front sub frame with shockwaves and an airbar in the rear. I will be using DSE mini tubs and a custom moser rear( so I can shorten it ). I want to run 18's all the way around and don't want to worry about rubbing. Will a 275/35/18 and a 335/30/18 work for my nova? I'm limited to using only what bfg offers in tire sizes.
      May 2002
      Northern California
      The fronts should be fine on the AME frame, excellent choice. run a 9" rim and your good. I know the AME frame can take a 10" but im not sure the body will.
      The rear choice might be a stretch. The frame will have to move. A 315 requires a half cut and with the wider 335 there will not be enough frame left to box....unless you move that section inwards. Running a link rear will not require the same amount of support a leaf rear will so it can be done. 18x12 is the recommended size. Backspace will depend on the lip you desire. That wide I like to run zero offset.
      Check with Frank at Prodigy Customs about the 335's and the airbar. It can be done but it will just require a bit of work and ingenuity. Welcome to the site and hope to see pictures of the progress.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      I'm gonna price out my options.
