    Thread: 517 Hp Lt1!
      La Plata, MD
      517 Hp Lt1! (now with video)
      Well I get a call from the machine shop on my way home from work and they tell me that in an hour and a half they will be running my motor on the dyno. So I rush home and change clothes and bust hump to the machine shop.
      So to the point, my LT1 was stroked to 383 cubic inches, running stock type heads with bigger valves and a full port and polish. CC cam about .600 lift with 230 duration on a 107 LSA. Running just for the ease of it on the dyno - victor intake, 780 Holley, MSD ignition, and shorty BBK headers.
      First run was about 478 HP, I was hoping for more
      Second run bumped up the timing and the motor fell off, Darn
      Third run pulled some jet out of it put the timing back where we started and pulled 517 HP! Can you say stoked!
      Fourth run pulled some more jet out of it since it was still rich on the top end and pulled about 503 HP, not as good but the power at about 6200 RPM was about 35 HP higher so total power under the curve was better.
      Motor pulled 400+ ft lb of torque from 3600 to about 6100 RPM which I thought was pretty impressive.
      My goal was to make 500 HP so it looks like mission accomplished, when I get the dyno runs I will try to post. Just had to tell someone.
      1968 Pontiac Firebird
      LT1/T56
      Bruce
