    Results 1 to 12 of 12
    Thread: Chassis Paint?
      Jul 2007
      Northern Virginia
      Chassis Paint?
      I have a 1996 Impala SS frame that can not be powdercoated, due to GM dipped these frames in "Black Paraffin Wax" during production for rust proofing. The frame has been completely sandblasted but I was unable to get into the boxed areas of the frame to remove this wax and the powdercoater says this wax will melt as the frame is brought up to tempature during powdercoating and ruin the job.
      So, now I would like to paint this frame. What are some paint recommendations to have a result of semi-flat black.
      Thanks in advance
      Ray
      Jul 2002
      Mesquite, TX
      Ray, I don't have any useful suggestions on the paint, but couldn't the powdercoater heat the frame first to melt out the wax before doing the coating?
      ppg dp 90 It's a semi gloss 2part epoxy
      Jul 2007
      Northern Virginia
      Quote Originally Posted by derekf
      I brought that same idea up to him also. He said he could not be held responsible if any residue wax remained and ruined the coating.
      Greenwood, SC
      Quote Originally Posted by comp-spec
      x2
      or find something from the por-15 website.... they might have some other paints made for subframes and underbodies...
      JC Scott
      Jul 2007
      Northern Virginia
      Would I top coat it with clear or leave it as is? I'm concerned about the UV factor of PPG DP90 since this car will be in car shows with the hood open and frame exposed to the sun.
      Jul 2007
      Wake Forest North Carolina
      Quote Originally Posted by SSTuner
      Find a different powder coater .. the preheat is meant for exactly this purpose. But the paints are pretty durible anymore.
      I would leave it as is.
      I don't think the sun is going to hert it.We have cars that have bin done for along time with no problems and its definitly one of the most durable for a chassie
      Feb 2003
      St. Louis, Missouri
      Eastwoods Chassis Black works pretty well.
      Oct 2005
      Graves County, Ky
      The powdercoater should place the parts in the oven first, to burn off any contaminates before they powdercoat the parts. Ask your powdercoater if they do that first. They should not just coat your parts, then cook them. I've had just about every part on my Camaro coated, and every part has been cooked first to get contaminates out before they coat them. Just my .2
      Jonesboro, Arkansas
      Heating the parts prior to powder coating is a process that isn't to get rid of contaminents, but because the powder "melts" onto whatever is being coated. Most powder coating is done at a relatively high temperature. What your powder coater is saying, if I'm correct, is that when he brings your frame up to temp, the wax is going to run out of different places and run down onto the places that will receive the wax. I don't think the temperature is going to be high enough to completely burn the wax off the surface of the frame, and if it is, the residue left behind will probably cause adhesion problems. He just doesn't want to be held responsible, IMO...
      dayton, oh
      you could stand it up on end in your yard, and hit it with the torch for awhile. flip it over, and do it again... ?
      dave.t
      74 Javelin AMX - stocker
