    Results 1 to 9 of 9
      how much do i cut?
      I need to lower the front end a half inch, and need to know how much coil to cut to achieve this. I just updated to SC&C stage 2 kit tried the Eibach springs and was just to low. Put the stock height springs back in and is close but would like to drop another half inch
      Dec 2007
      Gilroy, CA
      lol i know this isnt what you want to hear but you should cut 1/2 a coil at a time so you dont go too far.
      Do it over the course of a month or if you are crazy a week.
      Cut the spring half a coil reinstall, drive for a day.
      Want lower? repeat.
      1969 Chevelle
      www.creationsultd.com
      Mar 2002
      Redwood City, CA
      A half inch could be difficult to reach. It could be as little as 1/4 coil at a time to get that, but it might get you lower. It's just something you've gotta be careful with, and try to be patient about it. Also, see what Marcus would suggest you do.
      Allen Ortega
      May 2002
      Northern California
      1/2" I'd go put a few hundred miles on it first.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      May 2000
      You could also put the Eibach springs back in, and then ad a spring rubber between the coils to see if that put you where you wanted.
      Washington, MO
      Quote Originally Posted by MarkM66
      I think this would be the best option since the Eibach's have a stiffer spring rate and wont sag like a stock spring will.
      To me it just doesn't make sense to use a stage2 kit and then go with mushy stock springs.
      Orlando, Fl
      Someone else recently had this issue with Eibach springs and Marcus chimed in saying that Eibach has been mismarking some of their parts. You may want to give him a call...
      Thread in ? here:
      https://www.pro-touring.com/forum/sh...ad.php?t=41130
      Jan 2002
      Italy
      normally the rate is 2-1 due to the fact that the spring is halfway between the pivot point and the spindle.
      This means that whatever you cut, the car will be lowered the double of that.
      If you want the car 1/2" lower I'd just drive it around a bit before doing anything as Mrquick suggested.
      Have Fun!
      André
      2009 Chrysler 300C Touring.
      3.0 liter V6 diesel, five speed auto, black with light grey leather.
      1968 Chevelle Coupe.
      355cid, Viper T56, Corvette C4 IRS (Dana 44) and Corvette C4 IFS with Porsche 6piston Brembo's.
      1980 Chevy Van (shortie G10).
      355cid, TH350, 8.5" 10bolt posi and Belltech spindles.
      2000 BMW 540i Wagon. (FOR SALE €7K)
      4.4 liter V8, six speed manual, lowered and with Bilstein B8's, silver with black leather.
      2001 Ford Focus Wagon.
      1.8 liter turbo diesel, and a whoppin 90HP.:bsjerk:
      1968 Benelli Motorella
      foldable 50c scooter to go in a car trunk.
      2x '90s Yamaha TZR 2stroke bikes.
      one 125cc one cylinder and one will be 350cc two cylinder.
      thanks guys, i will drive it for a while and see what happen's then go from there.
