Thread: D1sc Accessory Drive Question
03-26-2008 #1
Hi all! Need some help on this one...anyone have BBC with Procharger and AC/PS/Alt drives? I am running the Mez high flow electric and 12 rib s-c drive belt. Need to know what options I have for this set-up.
Any help???
Jim Light
Owner/President, GGC Enterprises
71 Camaro RS, 383 Vortech Blown, TKO600, 9" w/3.55's, Wilwood Brakes, 17"f/18"r.
Under Construction:
68 Camaro RS, 496 BBC D1SC Blown, T-56, 12-Bolt Posi w/4.56's, C5 Brakes, HRE 545R's 17"f/18"r, G-West uppers and Sway-Bar, AFX Spindles, Del-a-lum's, Lee 12.7 Steering Box, Bilstein Shocks, and DSE 3" Drop Rear Multi Leaf Kit w/Koni's.
Other Cars:
69 Camaro RS w/355 & 6-71(drag set-up), 07 Velocity Yellow Z06, 06 Magnum SRT-8, 69/74 Nova ProStreet w/468 & 8-71, 03 Mercedes CL500, 04 HD 3500 Dually
03-27-2008 #2You probably want to get a hold of Jody (camcojb here) because I think he had almost the exact same setup (made by SD Concept Engineering).
Frank at Prodigy Customs also is a whiz on Procharger setups.Project "Freebird"
03-27-2008 #3I have all those accessories except my Meziere high flow is mechanical.
Originally Posted by TnaGuy
What are you trying to do?
03-27-2008 #4Is your setup carb or EFI?
Project "Freebird"
03-27-2008 #5EFI
Originally Posted by speedster
03-29-2008 #6Thanx Speedster...I'll check with them both and see what they have to say.
I want to drive the accessories with the cleanest set-up possible, and the options seem limited from what I can find. The Elec WP makes it more complicated it seems...
I am going Carb, not FI.
Any other suggestions?Jim Light
Under Construction:
Other Cars:
03-30-2008 #7camcojb's set-up is diff, and Frank could not help at all. Any other ideas?
Jim Light
Under Construction:
Other Cars:
04-08-2008 #8Have you looked at March's brackets for the electric water pumps? They make a bracket for each of the main electric water pump brands. Hope that helps!
