    Results 1 to 20 of 21
      Rockford Illinois
      How many gauges do you have and why?
      I am about ready to order the rest of the gauges for my car and thought it would be a reasonable question for us all as to how many gauges you have and why and also if there were gauges you wish you would have had and then you would have known about a problem before it stranded or disabled you?
      Gauges like rear end temp seem to be a good example as a saftey warning before it locks up or breaks , things like that.
      So let it be known why you use what you do and maybe why you don't use them ?
      Mountain View, CA
      Interesting topic and one I've thought a fair bit about. I'll be interested to see what people have done, or wish they'd done.
      I'm planning on having:
      Tach
      Speedo
      Oil-P
      Oil-T
      Water-T
      Trans-T
      Amperes
      Fuel-P
      Fuel-L
      Not sure how to package it, let alone any additional gauges.
      True T.
      My blog
      Mar 2002
      Redwood City, CA
      Quote Originally Posted by Damn True
      Tach
      Speedo
      Oil-P
      Oil-T
      Water-T
      Trans-T
      Amperes
      Fuel-P
      Fuel-L
      True, a Volts guage would be more useful than a Amps guage. Just to let you know.
      Allen Ortega
      Mountain View, CA
      Quote Originally Posted by zbugger
      Dang, I knew that. What a dope.
      True T.
      My blog
      Greenwood, SC
      What is the point of runnin air to fuel ratio gauge? Is this good to monitor? How can you change it if it is not good? What can it help you to understand about the engine's performance?
      JC Scott
      El Dorado Hills, CA
      Quote Originally Posted by cheapthrillz
      For me, it has helped a ton in terms of trying to tune it better and not just try to tune it via Vacuum gauge and feel. I get a good idea of when its running too rich and robbing power away at WOT on initial floor it, it let me know I needed to change my pump cam on the secondary and also when I needed to up the jets on the carb too, because it was too lean when reading it on the AFR....
      I have a blower motor, so I want to be able to keep an eye on everything I possibly can, last thing I need is for it to be to lean and burn up before I can really enjoy it.
      Brad
      68 Camaro - Procharged LQ4 coming - Currie 9" narrowed, bagged, lays frame, BMW projector HID's LED tails, 18"s, lexus center console, seat warmers, A/C... Mini-tubbing in progress!!
      07 BMW 750li -loaded
      Washington, MO
      I was planning on:
      Speedo
      Tach
      Fuel L
      Volts
      Water T
      Oil P
      Trans T
      Jan 2002
      Crockett, Texas
      Speedo
      Tach
      Water T
      Oil P
      Oil T
      Fuel L
      Vac
      Volts
      Trans T
      Don 67 Camaro RS/SS Texas
      Feb 2008
      Sesser, Il
      Hopefully I can add to this by asking another question...
      Those who are/will be running a trans temp gauge...is this for an auto tranny and is there an advantage to running one in a manual tranny?
      Doug
      Doug Gulley
      Feb 2008
      Minneapolis, mn
      factory speedo and gas gauge in the dash and a volt meter, coolant temp and oil pressure hanging under the dash. I dont run a tach since its a street driven auto tranny car.
      Mar 2002
      Redwood City, CA
      Here's my setup. Speedo, Tach, Fuel level, Volts, Water temp, Oil Pressure, Trans Temp, and Vacum. I still need Oil Temp and Fuel Pressure. I have the Trans Temp because of my automatic transmission, and Vacum because I learned to read one in school to diagnose engine internal issues. The other two needed guages will reside in the A/C vent in the dash. Or I'll rearrange my current setup to keep everything together. I haven't decided yet.
      Allen Ortega
      El Dorado Hills, CA
      Damn Allen, I did not know you had this all done already! Looks good!!
      I am running:
      Speedo
      Tach
      Oil Pressure
      Vac/Boost
      Water temp
      Volts
      Fuel Pressure
      Fuel Level
      And then I am also running the FAST AFR and Devil Own progressive controller, not the typical 2 1/16 or 2 5/8 sizes so I put them sonewhere else.
      Brad
      Rochester, NY
      Vacuum gauges are also very useful for increasing you fuel mileage. My Benz had one disguised as an 'economy' gauge and if I kept an eye on it while driving I could score a few more precious mpg's. It also told me I had a vacuum leak which I never could find.
      Things like rearend temp gauges and things like that seem a little ridiculous on a street car but then again a friend of mine was nearly killed being thrown out of the t-bucket she was driving when the rearend locked up at about 75mph and it flipped over the guardrail.
      Ultimately I'd like:
      Speedo
      Tach
      Water temp
      Oil Pressure
      Volts
      Boost/vacuum
      Fuel level
      Jul 2007
      Los Angeles, CA
      I was planning on:
      Dash Cluster:
      Speedo
      Fuel Level
      Tach
      Center Console Pod:
      Voltage
      Fuel Pressure
      A/F Ratio
      Vacuum
      A Pillar Pod:
      Water Temp
      Oil Pressure
      Under dash:
      Trans Temp
      Oil Temp
      Walla Walla, WA
      Dash cluster: 5" Tach & Speedo -reason is obvious
      Elsewhere 2.625" - likely custom console
      Oil-P - need to monitor
      Oil-T - need to monitor
      Water-T - need to monitor
      Trans-T - because they make one
      Volts - need to monitor
      Fuel-P - EFI need to monitor
      Fuel-L - need to monitor
      Mike Kelcy - '68 Camaro with some stuff done to it.
      Washington, MO
      Good idea... Looks like I'm adding the Vacuum gauge to the list.
      I run all the usual ones (tach, speedo, w-t, o-p, o-t, f-p, f-l, volts), plus 2 brake hydraulic pressure gauges.
      jp
      ​John Parsons
      For extra information like trans and rearend temps, you might want to consider idiot lights instead of gages. If you go too crazy on gages, you're not going to be able to follow them all anyway.
      Engine temp, oil pressure, voltage, tach, speedo, fuel, should be standard. Air/fuel can also be helpful.
      Vacuum and fuel pressure setup as temporary while tuning. Or you can maybe put them in a less conspicous location.
      Rockford Illinois
      This is just starting to get good and I want to put some food for thought into this.
      If you had 12 channels to record all of the pressures and temps so you could look back and see what was going on all of the time as the events happened for hours at a time what info would you be looking for ?
      It really is a good way to look at it that you only need warning lights and not actual gauges to monitor some things because until you actually get a baseline you can't really set a good warning value, also since you can go back and look at the data so visually monitoring a gauge is uneeded once the warning parameters are set.
      So let your dreams go wild and let's see where it takes us?
      For what the cost of nice gauges are costing and what really nice gauges are costing these days, the price isn't that far out of a budget anymore and just a readjustment on a tire and wheel package can make enough of a difference to put you into the future with your gauges and it is much easier to change your tires and wheels later.
      There seems to be a lot to discuss yet so keep it coming
