    Thread: -8 too small?
      livermore ca
      -8 too small?
      i am re-running my lines for my oil filter mount and was woundering is -8 line is 2 small for oil lines? should i use a -10?
      https://www.pro-touring.com/forum/sh...ad.php?t=22724
      65ss chevelle
      95 lt1 LE2 heads gm847 cam, 1.6 gold sereis roller rockers,52mm tb,37lb racetronix injectors. hooker headers
      63ss nova
      350:cam headers,roller rockers.pete jackson gear drive,
      th350 shift kit 3,500 stall
      3:73
      **Drive it like you stole it!!
      Newbury Park, CA
      -8 hose ends can be pretty resrictive.
      Aug 2001
      Wilton, CA. (Sacramento)
      #8 is too small. A friend had a 65 GTO with #8 lines to a remote filter. Kept spinning bearings, finally realized what he'd done wrong. Went to the larger line, no more problems.
      Jody
      livermore ca
      ok thanks guys looks like ill be buying -10 stuff for the remote filter
      65ss chevelle
      63ss nova
      3:73
      Henderson,NV
      My moroso remote oil filter mount said minimum -10. I am hoping to get away from remote all together with my new headers.
      Todd
      Oct 2007
      ridgefield ct
      just in case i'll ask, what about for a cooler? does it really matter as long as it does flow?
      Central CA USA
      Also don't use 90 degree elbows, if you need a 90, get a 90 deg hose end, they have an easier bend, less restrictive. A 90 elbow has a very sharp corner inside.
      David
