    Results 1 to 11 of 11
      Holmes Hollow, Ontario Canada
      which rear to run
      I've been looking over some of these posts and I'm a little confused. I've got a 68 firebird with a 10 bolt pontiac rearend (8.2) and 2.73 gears,drum brakes. I want to upgrade to a 3.73 posi disc set up. From what I understand, nothing higher than the 2.73 will fit in that case. Is this true?
      I assume it is so I started looking for a disc brake donor. What I found is a 9" lincoln with discs and a 8.5"posi, disc rear out of an 81 trans am. Which one am I better off with. From what I understand from http://firstgenfirebird.org/firebird...xle/axles.html, the 2nd gen rear is the same width yet here it says they are different. Anybody know for sure? And if the 8.5 is almost the same strenght as the 9" and I don't need more than mentioned in the other posting (400hp tops) then I shouldn't waste money on buying a posi for the 9".
      Which rear do I run? The lincoln 9" or the 81 trans am 8.5" or is there another cheap alternative?
      Thanks Scott
