Thread: A-Body Spindle Brake Combo Info
- Mar 2008
- 2
Hi,
I have a oval track stock car, square tube frame and a second gen Camaro front clip. At present time I have an after market spindle, but rules have changed to an OEM spindle only. Most cars here are using the big Impala spindle and rotor combo. I want to use the A-body 2 piece spindle since I have a rare set of 8 degree 442 spindles. My question is this: is there a 5x5 bolt pattern rotor combo that will bolt up to this spindle directly? Someone said possibly that the 73 to 77 Chevelle spindles would work and they had a set that were redrilled to 5x5. I am also thinking that since I use a 5 inch offset wheel, that the bolt on steering arm would give me more tie rod tire clearance than the one piece Impala spindle. Thanks in advance. This is a great site.
