03-20-2008 #1
- Sep 2007
- 8
rookie distributor curve question-
I have a ZZ4 that hasn't been installed yet. I need to ditch the HEI that's included with the ZZ4 because of clearance issues. I have an MSD distributor 8261 to replace it.
The ZZ4 webpage at GM performance parts spes the ignition timing as:
10 degree BTDC @ 800 rpm 32 degree total @ 4000 rpm with vacuum advance disconnected
http://www.gmperformanceparts.com/En...9712&engCat=sb
So, should I:
Subtract the initial 10 degrees from the 32 total, and set the weights and stop in the distributor to go 22 degrees at 4000 rpm?
As I read it, that just happens to be the MSD set up right out of the box. MSD states that's the slowest advance curve possible.
I'm wondering if I should skip the suggested curve on the GM website and choose an ignition curve in the middle of my choices and work from there?
