      May 2007
      Midwest City, Ok
      speedo 4sp manual
      My old man bought a 54' Chevy 3100 pickup with an inline6 and a manual 4spd. We can spin the mech. speedo cable by hand, but his speed is not working when hook up. Is this more likely a trans issue, speedo issue, or cable issue? Any help or a point in the right direction would be a great help.
      CHICAGO SUBURBS
      If you spin the cable from the trans end by hand, you should be able to get the gauge to move a little. You can also try to remove the plastic gear from the trans, to check the teeth. They strip pretty easy.
      Ft. Worth, Tx
      Quote Originally Posted by HILROD
      Exactly, pop the speedo bullet out of the transmission and see if either the inner or outer gears teeth are stripped, if not check your cable and see if turning it effects the gauge at all.
      May 2007
      Midwest City, Ok
      Thanks guys
      Ft. Worth, Tx
      No problem, hope everything works out for you.
      Dec 2002
      Lost Wages, Nevada
      Other things.......
      Sometimes the speed-o gear on the output shaft will move and it wont engage the speed-o gear teeth... or... it may not even be on the output shaft all together.
      I have seen ALOT of four speed rebuilds where the tech didnt re-install the output shaft speed-o gear. Even if you have a new speed-o gear to put into the trans... it doesnt do any good if the output shaft gear isnt there to begin with. Its just something to check.
