    Results 1 to 16 of 16
      Panhard bar brackets help..
      What are you guys who are using a PHB doing for brackets when the car did not originally come with a bar? Of the few that I can find for a solid axle, it seems they need to mount directly above the axle? What options are there?
      This is going into a Caprice with a 10 bolt, street driven, lowered 2".
      What Year Caprice?
      1979
      Loganville, GA
      I used this on my el camino, comes in weld-on or bolt on styles:
      http://www.speedwaymotors.com/p/3381...t-Weld-On.html
      The frame side was made from 2 x 3 box steel and used in conjunction with 2 of these:
      http://www.speedwaymotors.com/p/3371...g-Bracket.html
      The body was off the frame when I did it, it would be more difficult to do on the car, but possible.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      Randy,
      Thanks, that is just what I am looking for, great web site too.
      Can heim joints be set up to rotate in any direction? Obviously they can spin a full 360 degrees in the same plane as the hole, but can a panhard bar be set up with the rotation/arc of movement perpendicular to the hole?
      Feb 2008
      heim joints can handle some movement perpendicular to the mounting bolt axis, but there is a limit. how much depends on the heim
      Auburn, WA
      Panhard bars can be mounted ahead or behind axle centerline, assuming your brackets are up to the task.
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
      Aug 2001
      Connecticut
      I used the speedway brackets on mine, nice piece and good quality; good price too!
      1962 Corvette 327-340hp stock
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      great pic, thanks. You guys have helped a ton!
      Take a look at stockcar products also. They have a very nice notched frame bracket for double shear panhard bar mounting. The holes are close tolerance too.
      70 Mach I, dry sump & lots of mods
      70 1/2 Z28 project car
      Murphy, TX
      Which side of the car (left side, drivers or right side, passenger) would be the best location for this axle bracket? It will have a bias on adjustability either above or below the axle centerline.
      Loganville, GA
      The axle bracket is intended to be on the right (pass) side. You could flip it for the drivers side, this it would put the bar higher up in relation to the axle. Most of my adjustments are below axle centerline. The top hole in the bracket is just above axle centerline.
      1975 MGB Roadster
      2003 GSX750F Katana
      In my application, what would be the recommeded placement for the bar in relation to above or below the axle. I am primarily using the bar as a means to control side to side axle movement since I am running tight clearances with my wheels in the wheel wells. No road courses or anything, just a driver.
      Aug 2001
      Connecticut
      at center to below; the panhard bar height determines the rear roll center.
      2006 Corvette Z06
      PA.
      Josh, build your brackets with a large range of vertical adjustment so you can play with it. As you lower the PHB the car will push more and more and you`ll have to compensate with rear spring rate and roll bar rate. It doesn`t take long for that to get really uncomfortable in the street. Run soft bushings in the upper arms in at least one end to allow some deflection so that the PHB can dominate the RC and you don`t have 2 conflicting roll centers fighting to control the car. Keeping the bar closer to the original RC will also reduce possible conflict and make your brackets shorter and more rigid. There will be a lot more load on them than you might think. Triangulate them well and add a crossmember between the rails just above it to keep them from spreading under load. Mark SC&C
      Thanks Mark, I have some brackets coming and will have to mock up this weekend.
      Josh
