    Results 1 to 1 of 1
      Feb 2008
      help starter problem
      I cannot get my starter to disengage I tried to shim it starting with 1 shim and all the way up to 5 shims and still the bendix will not disengage I tried it with no shims and still the same thing I tried to pry it over to either side and see if maybe its not aligned right and still nothing bought a new started and its doing the same thing. its on a 396 bbc and the starter bolt pattern is offset I wonder if I get a starter with a straight bolt pattern will that work the block seems to have the holes for either starter any help will be appreciated
      thanks LES
