    Results 1 to 9 of 9
      Sep 2007
      9 inch center help
      I bought a ford 9 inch center section ( used ) for my housing and axles i have . What i do know is it is 35 spline MW spool , 4.56 gear and has a N on the case , Not sure if its a regular support or not . Iam needing to get a driveshaft made now and need to change from the 1330 series yoke that has 1.12500 caps on it to a 1350 series ( Which driveshaft will be ) . I can see if i can find a conversion joint somewhere , but the other problem i ran into is the th400 is a truck trans , so i need to get a new trans yoke as i get mixed input on using a reg. th400 yoke since the truck has a o-ring or something that stops the yoke from sliding in all the way .
      I fiqure changing the yokes would be best . Is thier a way to tell with out taking it completly apart if it has a crush sleeve or a solid one ?
