Results 1 to 20 of 25
Thread: Stronger than grade 8 bolts?
03-12-2008 #1
Are there easy to find fastners that are stronger than grade 8 ??
The reason I'm asking is that I just broke one off in my aluminum head and dont want that to happen again. Its one of the bolts that holds my pulley system to the head. I broke an original fastner (hex head that came with the kit, assume grade 5) in the iron head about 3 years ago. Replaced that with a grade 8 and no problems.
Today I was putting my pulleys back on the new motor, and used the same grade 8 bolt again with antiseize on it. As I was tightening it with a box wrench, using my finger tips, it just broke off before I even had it cinched down. I was no where near tweaking on it. The only thing I can think of is that for the last 3 years, that bolt has been getting fatigued and just gave way with only mild twist pressure.
So... I'd like to not to have to worry about it breaking off again in the head.
Are the ARP fastners stronger than grade 8 ??
I'd like something stronger that isnt hard to find... any suggestions ??
Ned
Manteca, CA
My '69 Camaro
My Camaro Movie
My '70 Cuda Project Thread
My Cuda Project Pix
Cuda Project Sponsors/Builders
Bruning Auto Design,
Bowler Transmission, Air Ride Technologies, American Autowire, Vintage Air, Comp Cams/F.A.S.T
Carter Hickman Designs
03-12-2008 #2Don't know, but someone on this forum will post soon enough.
If not you can always give ARP a call.
I was at a local car show and got a bussiness card for a guy that just sells fasteners. His name was Derek and the name of the company is DMP Fasteners. I have not done business with him, but his website looks pretty complete.
http://dmpfasteners.com/Rick
" Better to Be Lucky than Good "
03-12-2008 #3Im pretty sure the ARP studs are stronger then grade 8 bolts.
1993 Camaro Z28
2001 Camaro Z28
1969 Camaro
03-12-2008 #4
