    Results 1 to 15 of 15
      Oswego il
      viper T56 behind Gen 1 SBC
      has anyone done this combo. I have a T56 Im considering building with Viper input shaft and want to know whats required to make this work. I know the input shaft length is different so Im guessing the McLeod modular bellhousing is needed, anyway around this. What flywheel/clutch/spacers are needed.
      Oswego il
      I guess I should ask, has anyone built an T56 to handle 500+ ft lbs torque, is the Viper input shaft needed.
      Ive read all the tech on this site for t-56 swaps and quite a bit on ls1tech, ls1tech users go to a viper input/output shafts, the output shaft is needed due to the high loads from the torque arm. not an issue on a 1st gen T56 swap.
      it looks like the LS T56 is the simplest route with mech linkage which Im gathering parts for. Can it be built to handle 500+ ft lbs reliably.
      Aug 2006
      Oakland, CA
      I believe the input shafts are the same strength wise - it's the output shaft that is the weak link and I don't believe it has anything to do with the torque arm. The output shaft basically runs the length of the transmission and every gear is attached to it. I have an LS1 style T56 that has a viper 30 splined output shaft installed; the company I bought it from (six speeds inc.) guarantees it to 750hp, though many take them higher. Their car is running high 8s at 150+mph through one of these viper shaft LS1 transmissions.
      http://www.youtube.com/watch?v=bDOn4i54B0U
      1967 Camaro
      Felton, DE
      I have a D&D 30 spline Viper shaft. It's the output shaft as tiznodd mentioned that they replace. You can still use all of LS1 clutches and flywheels. You just have to swap your driveshaft Ujoin over to a 30 spine 1350 spicer yoke.
      1994 Z28 - 13.52@110mph 2.1 60ft T56, bolt-ons, suspension
      1978 Datsun 2+2 - 6.0L LS1 swap in progress
      1968 Firebird, 2820 dry- 2000 LS1, D&D Viper T56, RAM clutch/flywheel, 236/236 .651/.651 110+4LSA cam, victor JR EFI, 4150 TB, 42lbers, painless harness, Moroso 7qt pan, sfc, trac bars, 3" x pipe side exits, Telstars-30"MT streets/skinnies, mini-tub, 8.5" posi, richmond 4.56s, Hooker lLTs, Denny N20 DS, Fast dual wideband, Shotgun street scoop.
      http://www.myspace.com/shawnmacananny
      Aug 2006
      Houston, TX
      The 30 spline Viper output shaft is the big upgrade, but the Viper input shaft is also much beefier than its LS1 counterpart ... Both have the same 26 splines for the clutch, but the LS1 input shaft tapers down in diameter quite a bit after the clutch splines, while the Viper version has almost no taper.
      I've got both input shafts handy - I'll take a pic and attach it to the thread when I get a chance.
      Quote Originally Posted by tiznodd
      Aug 2003
      The GTO 6 speeds have been holding up to 500 / 500 RW in some supercharged cars I have seen. They are much cheaper then a Viper modified unit.
      Oswego il
      I already have my LS1 core that needs a rebuild. sixspeedsinc sounds like the place to go, shipping from IL to their shop on east coast will be the killer for me. The viper upgrade is around $600, just trying to decide if I need it. Engine will be a 434 SBC, Im building it mild at 500 hp 5500-5800 rpm range but the torque should be huge, want more of a driver than a racer. I probably need the viper shaft.
      I wont be using the Pontiac nascar heads I have on it at this power level, they need much more rpm to work well, thinking AFR's would work better.
      Aug 2006
      Oakland, CA
      Quote Originally Posted by indyjps
      It's a bit of a crap shoot. Some LS1 cars make big power on stock output shafts and others break them with near stock power. Do you plan to run sticky tires? How aggressive of a clutch?
      1967 Camaro
      Socal, Ca
      Indyjps,
      Try http://www.classicchevy5speed.com/----------> sponser
      They have a 6 speed conversion that can handle some power
      Aug 2001
      Connecticut
      Rockland Std gear does offer upgrades to t56 to their 'son of tranzilla' specs which is suppose to be good for 800ft-lbs.
      http://www.rsgear.com/transmission.asp est I was told ~$1400 parts/labor.
      1962 Corvette 327-340hp stock
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      Viper 6 speed to sbc
      We got the parts on the shelve to bolt a Viper trans up to a chevorlet. You can use a stock bell housing and clutch linkage.
      PM me for more info if you are interested.
      Kevin
      Viper trans
      Oh, FYI a viper trans has a SAE torque rating somewhere around 500 bl-ft. SAE rating is for 24 hours.
      Kevin
      Oswego il
      Thanks for the input guys, Im thinking of using a centerforce with LM disc, If I do run slicks the suspension wont be set up to launch hard.
      Feb 2006
      Tennessee
      BTW, Six Speeds Inc is in Houston, TX.
      I used them for my T56. Just call Amber with any questions you have on strength. She told me the stock shafts would be fine with my 454 if slicks weren't a constant thing.
      Oswego il
      OK one of their competitors is in the carolina's.
      I will call Amber.
      shipping to Carolina or Texas is about the same for me
