    Results 1 to 10 of 10
      Oct 2005
      New Washington, IN
      How to build a 250 small block
      Okay, first let me just say, it is to meet class requirements.
      I would like to see what it would take to build a 250 small block. Actually it can be as large as 260.
      One guy is using a 305 block and destroked crank. I would think a 4" bore would be better.
      What do you think? What stroke would be needed?
      1971 Camaro 427 in waiting
      1988 C1500 Daily Driver
      2.25 ish.
      You could rev it to the moon with that stroke.
      The Gutless Cutlass, is no more.
      '73 Chevy C10, Low with lots of GO!!!!
      Pittsburgh, PA
      A 305 block will need a 2.85 stroke
      A 350 block will need a 2.49 stroke
      It just seems like the package is bigger than it needs to be. How about some more details. Do the rules dictate the engine architecture?
      If you are just looking for a small cube V-8, why not, say an Aurora 4.0 v-8. 240 cubes approximately.
      Just thinking out loud...
      Shane
      Oct 2005
      New Washington, IN
      Well rules only dictate size. MAx of 260 and it can not have fuel injetcion.
      Oh, it will be blown, weather turbo(s) or blower not sure yet.
      I looked at building an inline6, but parts costs were starting to add up more than a small block.
      Winchester, VA
      Well, if you can find one (which shouldn't be too hard), a 267 block from a 1979-1982 Camaro, Malibu/El Camino/Monte Carlo, or Impala/Caprice---bore = 3.50", and a crank from a 307, stoke = 3.25", then you'll have a baby mouse that comes in at 250.1 cubic inches. You can technically use a 3.00" stroke crank for a 230.9 cid, about the smallest able to be made from factory parts, but the 250 is about the size you want. Good luck!
      EDIT- After some more research, since both the 267 and 307 (and pretty much most small blocks) used 5.7 rods, you could probably use the 267 piston, too. Here's how. What you would need to do is get the rods from a '94-'96 Chevy Caprice with the L99 4300 (baby LT1). They are 5.94" long. The difference between the 267's 3.48" stroke and the "new" 307's 3.25" stoke is 0.23". The difference between the 5.7" rod and the L99's 5.94" rod is 0.24". So if my calculations are correct, then that's pretty much a direct swap.
      267 block - 3.50" bore
      + 307 crank - 3.25"
      + L99 (4.3L) rods - 5.94"
      + good flowing heads (small chamber and valves)
      + smallish cam
      = decent hi-winder super-small block at 250.1 cid.......+ power adder = unlimited ???
      Wayne Smith
      '70 Camaro - 406 - Street/Strip being converted to Pro-Touring (best 1/4 run - 11.05 @ 121, 1.50 60' - NA)
      '47 Chevy truck - 250 L6 / 5 spd - Resto Rod/Work Truck in the works
      Oct 2005
      New Washington, IN
      Good thinking. I wonder what vlaves I could fit on that small bore though?
      I was thinking of using vortec heads, cheap and good, but I doubt they would work on a 3.5" bore. Anyone know?
      Winchester, VA
      Well, I'm know that the 350 Vortec's would be too large, but the 305 Vortec heads might work. They'd have plenty of flow for that little thing.
      Wayne Smith
      Oct 2005
      New Washington, IN
      Of course the boost would help make up for any lack of flow!
      Oct 2005
      New Washington, IN
      If I was to do this, I would hunt up a stock, Tri-5 265" engine and offset grind it's forged crank to a 2.92" stroke to make a 258" engine that will really cook! You will need a custom set of rod bearings or use Honda sized 5.7" rods and needed bearings.
      I figure a later 265 Baby LT1 can be used too, but it won't have a stock forged crank in it like the early engine will.
      I love stuff like this b/c the old 265/272/283/292/"301/302"/306/311/327/331/337 and such short-stroke engines can really be made to RUN!
      pdq67
