    Page 20 of 39 FirstFirst ... 10 15 16 17 18 19 20 21 22 23 24 25 30 ... LastLast
    Results 381 to 400 of 763
    1. #381
      Quote Originally Posted by trapin
      The tech in this thread is great, Andrew...but your issue with vibration in your drivetrain is causing me some anxiety due to the fact that I just set mine up over the winter dialing in the trans angle and having a new driveshaft built. If you're having these kinds of issues...I can just imagine what's in store for me.
      Tony,
      I wouldn't sweat it. Camaros don't seem to have too many issues with driveline vibrations.
    2. #382
      I got the wheel centers back today and they look pretty amazing.
      I should have the polished rims tomorrow and then I can start on assembling the wheels.
      During a recent trip to Chicago I stopped by The Parts Place and picked up a new pinion yoke. After installing it, I measured the run out and it was .004", quite a bit less than the run out on the other yoke which was about .040". I ran it up to speed on the jackstands and it was very smooth in 5th gear (1:1) all the way up to 4500 RPM. It still vibrated a little in 6th, but I think most of that is due to the fact that there is no load on the driveline. I am going to leave it for now and see how it feels going down the road.
      The brakes should be here next week, then I can be back on the road.
    3. #383
      Janesville, WI
      I liked you rims b4, but now...
      I'm a big fan of dark colored rims. Those look great!
      -Shaun-
      L92/T56 Stalker 1711 pounds, LS power!
      73 Buick Century L92/T56 swap in progress
    4. #384
      Quote Originally Posted by subtlez28
      Thanks Shaun. I got a better look at all of them and it seems one of the front centers got a little mark on it. :/ Should be OK with a little Sharpie magic...LOL
    5. #385
      Jun 2008
      Carol Stream, IL
      Wheel looks nice, look forward to seeing them assembled and on the car
    6. #386
      The best thing about black anodizing is that blemishes can be fixed by a Sharpie.
      I wanna see the whole wheel!
      jp
      ​John Parsons
    7. #387
      jp
      I am calling the polisher first thing in the morning and making sure he is done with them by close of business tomorrow. He promised! I am starting to get the feeling polishers are like interior guys. I am sure you understand John.
    8. #388
      Jul 2001
      Detroit, Michigan
      This is like a whole new car for you Andrew. Can't wait to see what the wheels look like.
      1968 Pro-Touring Camaro LS1
      Project: Next Year
      - Start date; June '01
    9. #389
      dayton, oh
      need to rename the thread: Version 3.0. ;)
      dave.t
      74 Javelin AMX - stocker
    10. #390
      Quote Originally Posted by jackfrost
      Nah....This is all part of what I wanted to do when I installed the LSx engine.
    11. #391
      Chicago
      The wheel centers came out the perfect color .
      Tony L
    12. #392
      At 4pm this afternoon I showed up at the polisher's place and the wheels were done, as promised. I have to admit the results were better than I imagined. This guy is simply amazing. His name is Jeff Smith and it turns out he did all of the brushed aluminum work on Bob Johnson's Cuda. I am pretty sure that they weren't this nice when I first got the wheels. I got them home, masked off the front, and spray painted the inner hoop silver. I figured that having a painted inner rim will be easier to clean than a plain aluminum one. After painting I applied a generous coating of wax to the polished surface to seal them a little bit. After that it was time to assemble the wheels. I lined up the center according to the marks that I made before taking the wheels apart. This way the wheels go together exactly the same way with the center going back to its rim. I used a little anti-seize on the splined section of the bolts and drove them through the center and the rim. Then I flipped the wheel over and started torquing the nuts in a star pattern. It took about 2 hours to do one wheel but the results were well worth it. It's like a brand new wheel!
      The little notch marks on the back are to keep track of the torque sequence. With 40 nuts to tighten, it is very easy to loose your place.
    13. #393
      Jul 2007
      So Cal
      Wow. Those look great. I can't wait to see those with the 40 series tires on the car.
      Tom
      1969 Chevelle
    14. #394
      May 2007
      Houston, Tx
      oh damn, I wanna see those mounted up!
      Colin Russ
    15. #395
      Andrew awesome job on the centers . He did a nice job on the polishing too ,they look like chrome. They are going to look sweet on your car
    16. #396
      SouthTX
      Awesome color and detail. What are you going to do about the center caps? Did the anodizer have a color similar to the original center color?
    17. #397
      Newbury Park, CA
      Quote Originally Posted by andrewb70
      My total bill was $160, but keep in mind that he reused my weld yokes, I brought my own slip yoke, and the rear u-joint was reused as well.
      That's a good deal Andrew. For exactly the same deal for me at IED, quoted and dropped off today, runs $233.
      Nice work on the rims.
    18. #398
      Newbury Park, CA
      I would like to see one of those done up for a cowl induction hood.
      I too am working on something but a bit different. Another month or so.....
    19. #399
      Quote Originally Posted by 4MuscleMachines
      The centers are going to pose a challenge. They are plastic and can't be anadized like the centers. I will think of something.
    20. #400
      Jun 2006
      NW burbs IL
      We have to remove the centers of our wheels when we run a track day. Personally I think the car looks mean without them. Take a measurement of the inner diameter and send me a pm, my budniks have a neat aluminum center cap that is held in with an o-ring that may be a close match.
      Matt
      Matt
