      Santa Cruz, CA
      New Member with a Chevy Blazer
      Hey, I'm Dave and glad I found this forum. I am a regular on S10forum(same name). I have a 98 Chevy Blazer that I'm building to haul on track and auto-x courses. I have already been to one auto-x, and far in the future plan to hit some track days.
      I'm in a car-club that has mostly imports and small cars, so hopefully I can show a few people up with a truck.
      Anyways here's a mod list and 10lbs of pictures in a 9lb bag
      1998 2 Door, LS, 4WD Model Chevy S10 Blazer
      Mods:
      Engine/Transmission
      Rebuilt 4.33L (262 bored .30 Over)
      Headwork on stock heads with Manley Race Valves(2.02int/1.5exh)
      Comp Cams 270AHR Cam
      Flowmaster 40 Series , Exhaust cut after the Muffler
      Custom Cold Air Intake
      Wait4mePerformance Custom ECU Tune
      JBA Headers
      Rebuilt Transmission with 'vette servos, better drive shell and 2200rpm Stall Convertor
      Polyurethane Motor Mounts
      Air Conditioning Removed
      LS1 E-Fans
      Suspension
      Belltech Nitro Drop Shocks
      Flex-A-Form Fiberglass 3" Leafs, 3" Belltech Blocks
      Belltech 4WD Drop Keys
      Polyurethane Body Mounts, Endlinks, Leafspring Bushings
      255/295 Kumho Ecsta MXs on Corvette C-5 wheels
      expand
      Interior
      NR Whiteface Gauges
      B&M Shifter
      4th Gen Camaro Seats
      Blue Gelled Interior Lights
      Niken Pedals
      expand
      Exterior
      Street Scene Grille
      Street Scene Mirrors
      Chrome Bow-Tie
      Removed Roof-Rack, Body Molding, Emblems,
      Home-Depot Custom Front Lip
      expand
      Weight Reduction
      Removed 4WD Components, Air Conditioning, Rear Seats, Spare, Roofrack, Windshield Washer Fluid Resevoir, Center Console, Wheel Swap, Camaro Seat Swap, removed rear wiper,
      Current Pics:
      Current WIPs:
      Custom Center Console, Custom Fiberglass Brake Ducts, Fiberglass Skidplate Copies(for aero), and a few other odds and ends, Rollpan, and frame notch
      Plans:Qa1 Coilovers for the front, QA1 Shocks out back with JTR Lowering Blocks, Eaton Posi, get the rollpan welded up, Racing seats/harness/rollcage, C5 Brakes all around, and maybe eventually some wide ass ZR1 (9."5F/11"R) Wheels with some R-comps, Aluminum Driveshaft(T-Case Delete)
      Eventually I plan to sell the V6/4L60E combo and get an Ls1-T56 Combo.
      The main weak points of the car so far is the stock front springs(replaced by QA1 which will drop about 70-80lbs), and the lack of a posi. On the autox my car will load all the weight to the front springs, and out of every corner im spinning TONS of inside rear tire.
      Here's a few more pics with my car club
      With the UC Santa Cruz Car Club I founded
      expand
      expand
      expand
      Only thing stopping me is a college kid's budget.
      Road Racing 98 Chevy Blazer WIP
      Feb 2008
      hey look its you.
      didnt know you had taken out the 4x4 stuff.
      Santa Cruz, CA
      Quote Originally Posted by greencactus3
      hey look its you.
      Hey what's up. I kind of ran out of things learn at S10forum so I'm trying to find new forums that will have the technical info and help I need.
      As far as weight reduction, yeah it's pretty naked compared to stock right now. In the cab there's Just a B&M Shifter, 2 seats and the dash, soon to have a center console. Rear Seats, seatbelts, spare and jack are all gone. I'm hoping to make this thing as simple and lightweight as possible. I still have to ditch the transfer case, and hopefully some day get lightweight spindles with Corvette hubs and eliminate the CV stub
      I have a brand new AGR 12:1 Steering box coming in the mail to replace the tired-ass 1990 Trans-Am 12:1 box I have right now. Can't get the damn thing to go straight right now
      Oct 2007
      Pensacola, FL
      Very nice blazer....
      I understand wanting the weight reduction, but why did you swap to an AWD t-case ?.... And if I'm not mistaken there are kits out there in the SY, TY, communities to convert to vette brakes on all 4 corners.....
      Santa Cruz, CA
      Quote Originally Posted by Crafty One
      Do you mean didn't get the AWD transfer case? I still have the stock 4wd transfer case, I need a new D-Shaft and tailshaft in the tranny for that to get pulled.
      First off that's alot of extra $$$ for AWD, which is the ultimate governing factor, but mostly I just didnt want the extra weight and maintenance with AWD, this thing is a blast RWD and can fit 305s stock in the rear, with a posi I should have some pretty solid traction.
      I eventually want to end up with an LS1/T56 Combo with an aluminum driveshaft. Ill probably do a few bolt ons for the LS1, but nothing major.
      If I can get this thing down to 3000 lbs or less it will cook with 400HP or more. It already feels pretty quick with the probably 260-280HP and 300+ft/lbs of torque, with an easy 300lbs of weight I could still stand to lose.
      I know there are conversions for C5 Brakes, but I want to go with aluminum spindles that have a C5 Style hub, so I can get rid of the extra rotating mass that my CV stub has and get a lighter simpler setup.
      My 4WD Blazer Spindles are ridiculously heavy.
      I want to eventually sell my modded V6/Tranny both of which have less than 10k miles on them. The tranny was done up by a shop and it chirps the gears when i floor it. I figure some muscle car guy or S10 guy would die for the setup, so that will pay for the swap quite a bit. It's got forged pistons and the tranny is good to 450HP.
      Once it's done I'd like to drift it too
      Oct 2007
      Pensacola, FL
      Sorry about the typo..... I was just curious to were you were headed. I've been wanting to build an AWD 2nd gen for a few years now. Just havn't found the right blazer.
