      LS1 Rear Brake Part Numbers
      I have a late model LS1 12 inch disk setup going on the rear of my 69 Camaro.
      The little rubber boots that keep the dirt out of the parking brake lever/actuator are shredded. I went to GM and the parts guy tells me I gotta buy the whole caliper braket assembly for like $150 to get the boots. Rediculous! Can that be right?
      Does anyone have a part number for those boots, a diagram, suggestions or?
      I thought someone made up a list of all the parts for the swap somewhere on the net.
      Thanks.
      Ontario, Calif.
      Good Start
      Thanks, much!
      I just need to find a diagram of the backing plate/caliper bracket with related parts. I was trying to find something on gmpartsdirect.com, but no images of the part numbers.
      Ontario, Calif.
      '82 El Camino w/ 95 LT1
      '02 Camaro SS a few mods
      '04 Silverado - the beater
      Thanks, again! That does the trick. Just where do you find this stuff?
      Ontario, Calif.
      A while back I picked up a .pdf file that has all of the 4th gen parts. It's basically what the dealer uses. I captured the sections you asked for and posted them. The file is about 125 megs in size.
