    Thread: Relay Block
      Nov 2004
      Imperial Beach, CA
      Relay Block
      Anyone know where I can get an inexpensive relay block that holds up to 6 relays?
      1967 Camaro -377, T56, Complete Ridetech
      1963 Nova SS Convertible - LS1, 2.8L Kenne Bell 8lbs., T56, Scotts Front Clip, HTH Truck Arm
      Hesperia, CA
      Look into Painless Performance's relay block kit. Houses 6 relays... pretty clean. Part # 30108.
      Nov 2004
      Imperial Beach, CA
      That is a nice piece but a bit expensive. Anybody else seen something like it?
      Dec 2007
      Mountain View CA
      Don't go with cheap (China) stuff. You'll regret it. There is some good stuff from China but buyer beware.
      Painless is worth it.
      Ron
      Montgomery, IL
      71 Formula, 455 SD/KRE D-Ports, Crower solid cam, TKO 600, 3:73 Eaton posi. 17" ARE 200s, , 1LE brakes, Koni, Rancho adjustable bars, Hotchkis springs
      charleston, SC
      Auto Rod Controls makes a block with up to at least 8 relays. It's a pretty cool piece. They don't have a website, but will mail you a catalog for free. Summit carries their products as well but you may have to call to get info on the entire line of products they carry.
      Robert's 1969 Camaro - 2002 LS1/T56, 10pt cage, Global West Stage III front suspension, HTH truck arm rear suspension, Sprint Cup 9" full-floating rear end, Fikse Mach V 17" up front 18" in the back and still working on it...
