      zachary louisiana
      fuel gauge not working
      i modified my 69 camaro dash and now have 5" autometers i out in a tach and speedo and moved my fuel to a cutom pod with 4 2 1/16 guages i just took the brown wire that was wired to the stock gauges and wired it to my new autometer's signal outlet. but it isnt working that gauges lights and ground and 12v is wired right just not the signal.....am i mising something.
      1969 camaro ss 372,hotchkis tvs, comp cams 268xe, world products heads, zz4 intake, 670 holley, msd setup eagle alloy 212's, autometer ultra lites......99 console with megashifter, ls1 brakes and a soon to be 700r-4
      http://http://www.cardomain.com/ride/2246580
      Tucson Arizona
      Ground going to the sender. Is reading at all? Pegged to full if I remember correctly means the sending wire is grounded or the sender is bad. Reading empty is the ground or sending wires are not connected at the fuel level gauge.
      I could have this backwards......
      Ok I found this link..........This should help you out!!
      http://www.chevelles.com/techref/ftecref18.html
      Joe
      "If you can leave black marks on a straight from the time you exit a corner till the time you brake for the next turn.......
      Then, you have enough horsepower."
      -Mark Donahue
