Results 1 to 17 of 17
Thread: Aftermarket blocks-sbc
02-29-2008 #1
- Aug 2004
- Milwaukee, Wi.
- 327
Which block would you get for a 1000+ hp (406), and why?
Dart, World or Bowtie (iron)
Are JE's "shelf" extreme duty, inv. dome pistons strong enough for this build?
What do you guys think?
Thanks, Steve
02-29-2008 #2Brodix or Donovan aluminum block, They handle abuse better and being aluminum helps cool better. all JE parts are worth using there the best piston company out there.
If you must have a steel block then a Bowtie or Dart, World products stuff is junk there blocks core shift alot and won't stay true.Thall shall fear no amount of boost, For thy bottle is with me.......
03-01-2008 #3
- Aug 2004
- Milwaukee, Wi.
- 327
I won't be able to afford aluminum, so iron is my only choice.
Are the Bowtie blocks as strong as Dart blocks? The reason I ask is because they are only "rated" for like 850hp.
Thanks, Steve
03-01-2008 #4I never had a problem with a bowtie block, have built acouple 900-1k hp dirt late model engines with them, and no problems
03-01-2008 #5either block would be a choice
03-01-2008 #6
- Aug 2004
- Milwaukee, Wi.
- 327
Thanks for the info, steve
03-02-2008 #7
