Thread: wiring help please
02-27-2008 #1
wiring help please
i have a few questions i am re doing my 69 camaro i put 5" autometers in the dash and all my other guages are electric so i am deleteing the dummy lights...my question is i am using 2 leds for blinkers and one for bright indicator...if im not mistaken the left blinkers are wired to the light with a aqua and a black. and the right blinker is wired with 2 blue and one black...why does the right side have 3 wires. and how do i wire the led black to black and my red to the blues....and does the same go for the blinker. and ok on a totallu different note on an msd setup billet dist 6al box blaster 2 coil the dist has 2 wires that are black striped with orange i think on one and purple on the other what two wires do i hook the to that come from the box........sorry for the questions i have my car stripped awith no front fenders and i ran over my dang harness and pulled all my msd wiring loose
1969 camaro ss 372,hotchkis tvs, comp cams 268xe, world products heads, zz4 intake, 670 holley, msd setup eagle alloy 212's, autometer ultra lites......99 console with megashifter, ls1 brakes and a soon to be 700r-4
http://http://www.cardomain.com/ride/2246580
02-28-2008 #2Anyone?
02-28-2008 #3
- Nov 2007
- 266
you seriously need to re-write your question because it is so grammatically incorrect, I had a hard time reading it. If Im reading right you are installing three leds for your turn signal indicators and hi beam indicator. First step is identify the wires. Easy rule of thumb is light blue has the L in it so its left and dark blue ihas the R so its the right (the rears are that way too, yellow is left cause it has the L's and green is right cause it has the R). Your hi beam is light green. To wire them to the leds, splice those wires to the red leads on the leds and ground the black wires. Thats all it takes and youre done.
1964 Malibu GT1 TWIN TURBO GEN 3 THREE LINK REAR
02-29-2008 #4for the right blinkers it has two blue wires going to the bulb and on the left it only has one for the right side do i attach both blue wires to the red lead on the led?
02-29-2008 #5
- Nov 2007
- 266
Ok are you talking about the connector? if so then look for the light blue and dark blue with two leads crimped on to one terminal. The other blue wire is the oil light lead and goes to the old oil pressure switch. And yes you need to maintain the splice so two wires on the red lead. Early I didnt pay attention to which car you had, I was sorta refering to an early car without a PC board style dash.
02-29-2008 #6
- Nov 2007
- 266
***** you confused me, take a picture of it and Ill write on the pic what needs to be done
02-29-2008 #7dang i dont have a pic on let me be more clear..on the stock 69 camaro dash you have the speedo and tach/fuel gauge under the gauges in the bezel are the dummy lights i think four one each side on the left side the bulb closest to the door is for the left blinker it has a light blue and a black wire going into it and on the right side in the other bezel the right blinker is farthest bulb to the right it has 3 wires going into it 2 blues and one black.. does one blue wire just jump back across and go through a relay?. so with that said i would need to hook both blues to my red lead on my led and on the left side light blue to red .....
02-29-2008 #8and on a separate note (im sorry guys i hate wiring and chasing wires.).....i moved stock my in dash fuel gauge to a cutom pod with 2 1/16 gauges i know that the brown wire is the wire i need so i cut it from the factory fuel gauge and wired it to the 2 1/16 fuel gauge that i just added. but it is not reading that i have fuel in the tank. it comes on i can see the needle move when i turn the key on and the light works but it isnt reading....what is the culprit?
