      Jan 2007
      Texas
      Starter not turning over
      Here it is: (1969 Camaro-400 small block) One the road for a week now.
      New ingnition switch.
      New wireing.
      Neutral switch good.
      Has been running and turning over no problem.
      Not too sure about solenoid....or... starter. Came with car)
      A few days ago, was driving around, stopped at Sonic ate burger.
      Went to turn over engine......nothing. The volt meter dropped off but nothing from the starter.
      After about 5 minutes of scratching, pacing and poking........ it turned over and away we go.
      BUT......
      Today in the driveway after a ride back from the parts store, I went to move the car after it was shut off for about 5 minutes....same thing again turn key nothing.
      battery is good, connections were tight.
      Now here is the weird part. I was grabbing for test wires and meter.....leaned in the window just for grins and it fired right up. It looks like a gremlin of some sort.
      If it happens again, can any body point me in a direction...... or is there someting I can check for so I don't get standed?
      Sounds like the solenoid when it gets hot next time when it happens go under the car and jump the solenoid (batt cable to start on solenoid) and see if it starts if it doesn't start let it cool down and then try again if it starts after cool down that's your problem
      Jan 2007
      Texas
      Sounds like a plan. I'll have the jumper at the ready.
      I'll let you know how it turns out....
      Also, I'll pull the starter an change out the soenoid....... maybe no need to trouble shoot.
      Houston, Tx
      Dad,
      I have heard of the same thing happening too. The heat from the headers saps into the starter. Once everything cools off it starts working again. Maybe putting some heat shield between the headers and starter will alleviate the problem. Maybe it's time to get a high torque mini-starter. I know that yours is a 50 lb monster... and no, that doesn't mean take the one off of my car
      Houston, Tx
      Here is a heat shield from summit... You just wrap it around the starter.
      http://store.summitracing.com/partde...5&autoview=sku
      Here is a mini starter. I can't remember the brand that I have, but this one looks like mine.
      http://cgi.ebay.com/ebaymotors/SBC-B...spagenameZWDVW
      Central CA USA
      Some solenoids stand the heat better than others. Standard Motor Products makes a good solenoid.
      Feb 2008
      Minneapolis, mn
      good strong battery, proper sized cables and a Ford Solenoid solved all my hot start issues.
      Nov 2007
      make sure the starter has a good ground. Also when it sticks if whacking the starter with a hammer gets it to start ,its a good time to replace it.
      Dan
      92 Vette LT1 ZF 6 speed
      94 ' Burb on 35s
      87 350 S10 5speed
      2012 Acura V6 TL Daily Driver
