    Results 21 to 25 of 25
      Feb 2008
      Sesser, Il
      Spec Stage 3 or Centerforce DF
      While I have my engine out rebuilding it, I'm planning ahead for my clutch/pressure plate and maybe flywheel choices. Here's my setup so far...what would you reuse or change? I need/want opinoins. This is a street only car that will never see any real strip action or stickie rear tires. Engine is a 383 SBC about 500 lb/ft torque with 2 pc RMS.
      86 Cutlass with 87 f-body pedals. Speed Direct mechanical linkage for a 78-80 a/g-body. 2pc rear seal T5 flywheel and 83 f-body Lakewood bellhousing. Aftermarket T56 transmission.
      I'd like to stay with the linkage setup so I can retain my bellhousing and I didn't really care for the f-body hydraulics that I replaced.
      Now for my questions. Resurface and reuse stock flywheel or replace with aftermarket steel? My Spec Stage 3 clutch/pp had a very stiff pedal and was either in or out...seemed like there was no modulating it. Remember...this is a street car and stop light to stop light usage. Would the Centerforce DF have any softer pedal feel and still hold?
      Doug
      Doug Gulley
