    Results 1 to 20 of 24
      Dec 2007
      Simi Valley, CA
      Nick Miserendino
      Used to be known as redzone001
      Dec 2007
      Simi Valley, CA
      Ok so its show and tell time.i dont know about anybody else but im always interested in seeing other fabricators skills and techniques. so ill go first.
      Nick Miserendino
      Oct 2007
      Southeastern MA
      Didn't you do the F-Bomb? Great work!! Wait-the first photo is rhe F-Bomb,isn't it?
      Woodbine, MD
      holy crap......all I can say is wow!!
      VA
      wouldn't want to put mine up after yours. You did a nice job there. I always have the problem with the bars springing after I bend them, so they arn't bent far enough or too much. Seems like I can never make them look perfect.
      Dec 2007
      Simi Valley, CA
      Roll Cage Fabrication
      Yep the first one is the F bomb. and thank you very much. come on now put up some pics!!
      Nick Miserendino
      Dec 2007
      Simi Valley, CA
      Quote Originally Posted by Ricoch3T
      i think it depends on what kind of bender you have but i aways go 2 to 3 degrees more then i need to. all tubing has some spring back 4130 seems to have more the DOM mild steel but i guess you will get a feel for it the more ya do it.
      Nick Miserendino
      VA
      Quote Originally Posted by redzone001
      I think its a J squared bender, but I can't remember now. I'd like to see if they make a hydraulic attachment for it. Its my fathers so I'm just learning on some scrap right now.
      How do yall cage guys weld on top of the two back bars coming from the main hoop?
      Dec 2007
      Simi Valley, CA
      Yes JD squared makes a hydraulic attachment. Thats the bender I have, it works great with the attachment.
      As for welding the tops of the cages it all depends on the car, sometimes you drop it threw the floor sometimes you have to grin and bear it and do it the hard way and squeez your head and tig torch into very tight places. thats the only part of cage building that i hate.
      Nick Miserendino
      Snohomish, WA
      I usualy arrange the fabrication so that I can tack the cage together in the car and before I weld the down tubes to the floor, I cut a holes in the floor and drop the whole cage down and weld the tops. It takes a little more planning, but it makes the structure that much stronger.
      "Way too much in not quite enough"
      Dec 2007
      Simi Valley, CA
      Here a few more.
      Nick Miserendino
      Aug 2005
      Redzone Fab
      Nick is an incredible fabricator beyond just cages.There are certain fabricators that you deal with that can bring more than what you were looking for to the table Nicks one of them.Tom Nelson
      Dec 2007
      Simi Valley, CA
      Thanks Tom. The Vett is gonna be Sick!
      Nick Miserendino
      Feb 2007
      ALABAMA
      did the back 1/2 and 4 link on the FJ and did it all on the 113" wheelbase Samurai.(yes i said 113")
      Feb 2007
      ALABAMA
      for you manual bender guys. i've seen this work on a pro-tools bender as well
      http://www.pirate4x4.com/forum/showthread.php?t=455001
      Nov 2007
      Vancouver, WA
      "street car" cage- tucked up to the headliner and a pillar as close as possible. Rolled bends follow the countours/shape of the roof. Besides aesthetics, the cage is tucked up out of the way. Same with the B pillar,,, you will hit your head on the rear side window first (getting in) before hitting the cage... Tig welded with a flat back cap on the torch handle
      1970 Dodge "E-Tikit" Challenger
      Quote Originally Posted by Bruning Auto Design View Post
      So you would Use a flat back cap on the torch handle to get into the Tight radius corners between the B Pillar and main hoop.
      Like what i have in my car.
      Nov 2007
      Vancouver, WA
      Was that a question for me or a statement?
      Quote Originally Posted by Nik@PTP View Post
      It was a Question Intended.... I believe i figured it out.. you would use a Mirco Tig torch to get into the Tight spots, and correct me if i'm wrong. Other than using a Smaller tig torch. is there a certain technique that you would use to weld up a cage that it pretty much tucked away?
      Thanks Nik
      Jan 2009
      So-Cal
      Depending on the layout and if you are thoughtful. Sometimes you can rock the roof hoop forward or backward after tacking, weld all the way around, then rock it back into place and weld in the supports.
