Thread: motion ratio on leaf springs
02-23-2008 #1
- Apr 2005
- Colorado Springs
- 761
On an independant suspensions, wheel rate can be calculated by squaring the motion ratio then multiplying the spring rate. Motion ratio can be calculated by dividing the distance from the coil spring to the pivot point by the length of the control arm.
Can the same be done on a leaf spring suspension and where is the cacluation points orginated at? Is it the drum face to roll center, drum face to opposite side spring, drum face to same side spring?
If my leaf is 120#, how much of that is being applied at the wheel?
