02-23-2008 #1
- Mar 2006
- So cal
- 249
Question: Can wheel offsets be changed?
Can wheel offsets be corrected?
Neighbor has some billet wheels made for his car and it seems the offset is a little off on the passenger rear wheel, he gets tire rub around corners and over certain bumps.
It seems like the wheel/tire should be about 1/8 or 1/4 inch further inward, and it does look like there is enough room, can this be changed and corrected?
72 Nova
02-23-2008 #2
- Apr 2005
- Colorado Springs
- 761
Offset is set when they make the wheels, so no,it cannot be easily changed once it is built unless they are multi piece modular wheels.
However, if one side is off and they other is not, I doubt it is incorrect offset in the wheels, but you can measure them to verify. I'd venture it rather is a slightly mislocated suspension component. Cars are mass produced and there are assembly variences built in to them. You get enough of these tolerances stacked up on one side and VIOLA! interference. He needs to verify that each wheel mounting face is in the identical position on each side.
There are always spacers...
02-24-2008 #3
