    Results 1 to 10 of 10
      Oct 2007
      Have AFX spindles for my Grand National, need some part numbers for brakes
      Hello guys, I have a set of AFX spindles for the GN and I just bought a new set of ZO6 calipers as well. These are not the loaded calipers so I will need everything else........Caliper brackets, hardware kit, bolts, PINs, etc.
      What all am I going to need and what are the part numbers? Quantity? I looked into Oreilly Auto Parts online and they saw I need 1 hardware kit. What all does this include? I also see they have a bolt seal kit, what is this? Thanks! -----Jeremy
      May 2002
      Northern California
      all i have are factory numbers....spring plates come with the pads.
      C5 ZO6 (red caliper) PARTS LIST
      caliper: 88895128 88895129
      pad cage : 12455799 2 req.
      boot kit : 12530703 4 req.
      guide pin : 12530697 4 req.
      rotor : 10445856 10445857
      banjo bolt : 11518571 2 req.
      copper crush washers 4 req.
      Bracket to spindle bolt : 11508133 4 req.
      caliper to cage bolt: 14067559 4 req.
      bracket to cage bolt: 39685 Fasenal M14-2.0x35mm Allen head
      Wheel stud: Dorman 610-323 OR Napa 641-1581
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Oct 2007
      Ok great. What is the cage? Also, what are the copper crush washers used for?
      Oct 2007
      I dont mean to be a pain in the butt here but could you give me a breaf description on how everything fits together? Which bolts go where and such?
      May 2002
      Northern California
      your really being a pain, nah its not a porblem.
      The cage is what they call a abutment or pad support. The bracket that houses the pads.
      The copper washers are for the banjo bolts that connect the brake fluid line to the calipers. One on each side of the line connection.
      I'll see if I can find the break down picture. I had it some where. Its not as difficult as you think it would be.
      Oct 2007
      Here is a list that Mark at www.scandc.com gave me. I'm trying to figure out the differences between the two lists. I am going to order these parts but I dont want to pay for the same things twice. I noticed you have a few parts that he doesnt have listed and he has a few you dont have listed.
      C-5 brake parts list
      The following are stock GM `97-`04 Corvette or direct replacement parts:
      Caliper mounting brackets
      GM#12455799 Qt.2
      Caliper bracket bolts
      GM# 14084051 Qt.4
      Calipers
      RH GM#12530682 / LH GM#12530683
      Caliper guide pins
      GM# 12530697 Qt.4
      Caliper hardware kit (includes brake pad anti-rattle clips and guide pin
      retaining bolts)
      NAPA United #83212 or equivalent Qt.2
      Hub/Bearing assys.
      SKF#BR930099, Timken#5131139 or equivalent Qt.2
      Lower Hub/bearing assy. retaining bolts
      GM#10414261 Qt.2
      Rotors
      Wagner BD125539, Raybestos 65701 or equivalent
      Brake pads
      Any `97-`04 C-5 Corvette direct fit pads
      Central Illinois
      The part number for the Banjo Bolt has been superseded. It is now 11570052. It only took them two weeks to get them
      '68 442 convertible
      5 SPEED - EFI
      '66 442 Hardtop
      in process
      May 2002
      Northern California
      Thank Chili,
      did you go through GM part direct? I will have to check my notes for a Dorman aftermarket replacement.
      Can't believe how much of it is superseded.
      Central Illinois
      I went through the local Chevy dealer. Napa had nothing and Autozone's website showed nothing. My local part store that always takes care of me (not the typical chain joint) showed 3 different banjo bolts. (2) 25mm and (1) 28mm - all same thread, but couldn't tell me which was correct. So in frustration I went back to the dealership and told them to order them for me. I figured $10 for two bolts is better than driving all over the place getting jerked around.
      Anyway, I appears the part number has changed three times. What I posted above is what they gave me.
      '68 442 convertible
      5 SPEED - EFI
      '66 442 Hardtop
      in process
      Does anyone know the actual piston sizes on the latest ZO6 calipers?
