- Aug 2004
- Rockford, MN
- 278
Converting '69 Firebird to Camaro steering??
Has anyone done this, or could verify if a straight pitman arm (Camaro style) would clear my Pontiac engine with headers? The idler arm is straight on the Firebird like the Camaro, so I'm assuming no issue there. Clearance looks ok at a glance. The main difference I've found is that the bird used a curved pitman arm to clear the factory manifolds.
Also, could anyone verify that the front subframe is essentially the same? I'm assuming a Camaro idler arm would bolt up to the same location as the Firebird part??
I've been told I can use the commonplace aftermarket parts for a '69 Camaro as long as I replace the centerlink (drag link) with a Camaro part (and possibly a '67-8 Firebird part), and pitman arm.
Thoughts?
1969 Firebird, Black, Parchment Arizen interior, Poncho 383 (4" crank), Kauffman heads, TKO600, Moser 12 bolt, Wilwoods, DSE, Speed Tech, Koni, Hotchkis, GW, 18" TTI's, VA Gen IV, etc.
