      Every day 4 link???
      I'm looking for a 4 link with out heim joints. I have a 67 camaro that I'm going to spend a lot of money on sound deadining and dont want the NVH if heim joints after 3000k miles. I would go the DSE route but I only have a 10 bolt and I'm not going to weld $1500 worth of bracketry to that, and really dont want to spend $2500 on a 12 bolt at the moment. One more question.....Is there a reason why someone couldnt make a end link out of a del-a-lum bushing?
      Oct 2005
      New Washington, IN
      What about Johnny joints?
      1971 Camaro 427 in waiting
      1988 C1500 Daily Driver
      Johnny Joints or Howe rubber bushings are your best bet. The Johnny Joints are a spherical bearing in a high durometer rubber race and the Howe bushings are more like a typical high durometer rubber bushing (with a welded stud to be used like a rod end) with less rubber for less distortion.
      Brian Escamilla
      '81 Sport Coupe 229 V6- Junked
      '94 Z28 - Parted Out
      Aug 2003
      Or, just get a G bar and be finished! You use your original lower leaf pring perche on the rear and you weld a couple tabs to the axle tubes.
